legacy data
Real-time Data
Legacy Data Real-Time Data
Raspberry Shake Data Center
Feed your research with high quality data
The Raspberry Shake Data Center (SDC) is online and ready to serve you. All (*) of the historical seismic data from the Raspberry Shake network is available for download using the SDC’s FDSN Web Service.
 Data from over 3,000 stations
Raspberry Shake operates the largest permanent real-time streaming seismic network in the world
200 TB of data
Since 2016, the SDC has collected over 60 TB of seismic and infrasound data, complete with instrument response files
Free access
All historical data is freely accessible via the SDC’s FDSN Web Service
Seismology’s first and only crowd sourced data center
Data from the Raspberry Shake network has grown enormously thanks to continuous real-time contributions from professional seismologists and citizen scientists alike. This is community science participation at its best.
FDSN Web Services
Use the SDC’s FDSNWS to access station metadata in FDSN StationXML, StationXML and SC3XML formats and time series data in miniSEED format. All (*) historical data all the way back to 2016 when Raspberry Shake was born is now online and available via FDSNWS.
IP to use for fdsnws queries:
https://data.raspberryshake.org/fdsnws/
(*) All historical data is available via the FDSN Web Service, except EN* channels (strong motion), which are limited to the past year.
Examples
fdsnws-dataselect example via wget:
Copy to Clipboard
fdsnws-dataselect example via ObsPy:
Copy to Clipboard
Peer reviewed publications
Scientific journals have already begun to publish original research that leverages data from the SDC. We have made the historical data freely accessible and easy to access. What hypotheses will you test?
Citizen seismology helps decipher the 2021 Haiti earthquake
A network of citizen seismometers installed in 2019 provided near-field data critical to rapidly understand the mechanism of the mainshock and monitor its aftershock sequence.
Read more…
Do Low-Cost Seismographs Perform Well Enough for Your Network?
Earthquake early warning systems and other monitoring networks would also benefit from network densification; however, current…
Read more…
Get in touch for help and further information:
For publication purposes, please use:
