Professional Seismic Solutions
All-in-one solutions for professional seismological applications such as Network Densification, Earthquake Early Warning, Aftershock Studies, Building Monitoring and Research.
Contact us for customized solutions
Fill the gaps between your broadband stations
Faster Earthquake Detections
Improve the speed and accuracy of automated detection systems
More for Less
Buy 100s of Shakes for the price of a single well-installed broadband station
Multi-Sensor Models
Choose the Raspberry Shake that best suits your professional application. All seismic, infrasonic and seismo-acoustic solutions were developed to create a professional low-cost, high fidelity solution that is easy-to-use, quick to set up, highly portable and ready to be deployed even in remote locations.
Technical Specifications
Specification | Description |
Software | • 100% SeisComP-compatible • Native SeedLink Server / miniSEED • Supports all FDSN protocols including SEED • Instrument response files generated automatically • Web-interface (HTML) for easy configuration |
Earthquake Early Warning (EEW) compatible | • 4 data packets/ second • 250 ms/ packet |
Digitizer Dynamic range | • 144 dB 24-bit ADC Sigma-Delta 𝚺𝚫 |
Timing | • Network Timing Protocol, NTP (default) • GPS timing supported |
Timing Quality | • +/- 10 ms or better |
Seismograph bandwidth | • -3dB points at 0.7 and 44 Hz |
Seismograph clip-level | • +/- 8,388,608 counts (24-bits) • 21 mm/s peak-to-peak from 0.1 to 10 Hz |
MEMS accelerograph bandwidth | • DC to 44 Hz |
MEMS clip level | • +/-2G • 21-22 m/s2 peak-to-peak from 0.1 to 10 Hz |
Immersion rating | • IP10 and IP67 enclosures are available for all models |
Peer Reviewed Literature
Global quieting of high-frequency seismic noise due to COVID-19 pandemic lockdown measures
“We compiled a global seismic noise dataset using vertical-component seismic waveform data from 337 broadband and individually operated citizen seismometer stations (24), such as Raspberry Shakes (RS), with a self-noise well below the ground motion generated by anthropogenic noise (25), and flat responses in the target frequency band. “
Take Your Research to the Next Level
Click below to see how scientists like yourself are using Raspberry Shake to enhance their monitoring efforts and complement their research initiatives.
On-Demand RS Data Archive
Raspberry Shake is 100% FDSN compatible and available on demand for researchers from Raspberry Shake’s FDSN Web Service.
Compatible Seismological Software
Raspberry Shake follows FDSN and SEED standards. Data generated by Raspberry Shake products is compatible with every popular software package in seismology, including:
AQMS, Antelope, Earlybird, Earthworm, Geospy, FDSNWS, Hydra, Matlab (GISMO), PQLX, Python (pip, matplotlib, ObsPy), SAC, SeedLink, Seisan, SeisComP, SeisGram2K, Seismic Handler, ShakeMap, SQLX, Swarm, WinSDR
We conclude that RS-4Ds are suitable for densifying backbone networks designed for studies of local and regional events.
It is more than a gadget! It can be used to locally densify networks to lower magnitude of completeness, it can be an alternative in regions where the situation does not allow the deployment of scientific grade seismometers, can also help for discriminating quarry blasts etc
It is a fun way to tinker with new technology, but it is also helping move the science forward. Not only the Raspberry Shake detect and visualize earthquakes, but having citizen scientists share their Raspberry Shake data increases Oklahoma’s seismic network coverage, and allows to detect more earthquakes more accurately. It is a win-win situation for everyone involved.
